TwinTurbo.NET: Nissan 300ZX forum - Re: Heat shield pads added to underbody helped reduce cabin
Subject Re: Heat shield pads added to underbody helped reduce cabin
Posted by 2T-Z on June 12, 2008 at 3:31 PM
  This message has been viewed 197 times.
In Reply To Heat shield pads added to underbody helped reduce cabin temp posted by Gordo 93TT Daytona on June 12, 2008 at 11:42 AM
Message I did not even think about the heat shields I took off that were connected to the stock exhaust. I kept the heat shields that were connected the the underbody on. I will order some of what you used hopefully it will help. Quick question first do you think it would help to use header wrap to wrap the downpipes and test pipes with instead? Just because the under of the z is a freakin mess...cleaning wont be easy 17 years of road grime...AAAHHHH
